B Series Parts For Sale!!!!! Cheap Prices
Old Jun 3, 2009 | 01:55 PM
HondaTom87's Avatar
Default B Series Parts For Sale!!!!! Cheap Prices
Parts For Sale:
B Series 10lb light weight flywheel $100
B16 oil pump does not have the crank position sensor $50
x2 22tooth b series water pumps stock replacements for b16, b18c1, & b18c5 also perfect for ls/vtec or b20/vtec builds $40 each (retail for $65 plus)
<br>
<br>
b16 pr3 rods $75 (with pistons but the pistons need to be replaced)
x2 obd0 PR4 ECU's (perfect for an LS Swap) $50 each
Stock 90-93 Acura Integra (DA) Rear Lower Control Arms $20 for the pair
Stock LS Water Pump $20
B16 Motor mount bracket (mounts on the block on the timing belt side) $5
Stock B Series Windage Tray $5
2 B Series Power Steering Pumps $20 each ( all are in great working condition)
Bosch Honda Alternator $50 (works great and the core can be used in other alternators) fits all b series engines
Si R AC Pump $50
Stock B Series Black Crank Case Breather Box $5
B Series Power Steering Reservoir $5
x2 90-93 Acura Integra Windshield Wiper Motors $10 each
90-93 Acura Integra Rear Hatch Wiper Motor $10
B16 Intake Manifold can be used for any b16 $50 (I will clean it and completely bring it back to stock conditions for $30 extra)
B series oil pan tapped for turbo oil return painted red $100
Turbo oil feed line kit. Comes with oil pressure sensor T fitting for the block steel braided line and the t3/t4 turbo oil feed bracket $50
Stock Gsr header with Heat shield $50
Stock H22 header with heat shield $50
Sock b18A B18b water pump $40
B16 throttle body $30
90-93 Acura Integra Power mirrors (these are the USDM ones and only fold manualy) $50
90-93 Acura Integra fuel rail will fit all B18A, B18B, and B20 motors $20
Will trade for aftermarket Integra Radiator, Slim fans, p28 ecu or modified obd1 ecu for manual vtec, gas mig welder, valve springs, type r or b16b cams, cam gears or let me know what you got.
All Prices are negotiable... Make me an offer... No Low Balling everything is already dirt cheap.
I have pictures of everything just ask for them.
Call/text/e-mail
Tom
9735906151
happletuning@yahoo.com
Old Jun 5, 2009 | 07:00 PM
project-dc's Avatar
Default Re: B Series Parts For Sale!!!!! Cheap Prices
i want the Stock B Series Black Crank Case Breather Box for $5 pm me
csmith21
Oct 10, 2013 02:20 PM
dodger
Apr 6, 2013 08:48 AM
HondaTom87
Northeast (Sales)
Sep 9, 2009 08:05 AM
neutron91
Texas -OK -LA (Sales)
22
Nov 29, 2007 10:04 AM
