b series trans internal question. LOOK ASAP
how the hell do i get that gear off the top of my diff. the trans speed sensor gear as i call it, cuz its to little gear on the tranny sensor shaft.
help asap. haha. i want this thing together in an hour.
what i did was put a piece of metal over the top then took my 3 arm bearing puller and pulled it off
now the important thing is with the 3 arm puller 1 arm will be up against the metal on the diff so i had to grind the bottom part of the arm down so slide under the speed gear the farthest (i chipped it before i ground it down so it save you the frustration)
with that being said just get a 2 arm bearing puller slap a piece of metal on the top and its cake
http://articles.evans-tuning.com/200...-differential/
in the middle video shows him pulling the speed gear, i wish he would have done the rest of it right lol
bam. i just did it like i do everything else. its ok. put the diff in the vice. got a piece of oak, and hammered it off with the two pound sludge. mint. thanks for all the help everyone.
2000Accord5sp
Aug 31, 2006 11:46 AM
