Honda S2000 Honda S2000
What offsets of rims are fit for S2000?
Old Aug 19, 2002 | 07:46 PM
YTYPER's Avatar
Default What offsets of rims are fit for S2000?
I want to buy a set of Volk Racing SE37 17" for S2000, but front and rear are difference offsets and sizes too. So what offsets for the front and the rear will be perfect for S2000 and what sizes of tires will be good?
Old Aug 20, 2002 | 08:14 AM
KF_S2000's Avatar
Default Re: What offsets of rims are fit for S2000? (YTYPER)
I can't help with wheel size and offset information, but I have read that the rear tires (labeled as 225 width by Bridgestone) are actually equivalent to a 245 width tire. The S-02 made for the S2000 are much wider than their width labeling indicates. Keep in mind that these are S-02 tires, S-02 Pole Position (not stock on S2000) do NOT follow this trend. Just some FYI when you go looking for tires. Good luck.
Old Aug 20, 2002 | 12:05 PM
jerrypeterson's Avatar
The SE's don't fit properly. 17" CE28N's can be custom ordered with the correct offsets (Note even with these wheels 235's in the front will rub). You want to have a ~25% stagger between the front and rear section widths, so don't freak on the different sizes front/rear(example 235 section width front mates well with 285 section width rears). Offsets are tricky, increasing width will require higher positive offsets.
Stock offsets are +55mm for a 6.5" front and +65mm for a 7.5" rear.
Check out the following link for more information:
http://www.s2ki.com/article/articleview/20/1/10/
BAYgasDC2
Mar 28, 2008 12:00 PM
balem827
Aug 2, 2006 07:44 AM
ak-s2000
Jan 29, 2004 08:28 AM
psdvette
Honda S2000
Jun 25, 2003 02:20 AM
