Suspension & Brakes Theory, alignment, spring rates....
coilovers
Old Jun 2, 2009 | 10:17 PM
98civtec's Avatar
Default coilovers
i have a 98 civic ex with skunk 2 lowering springs and i hate the rough ride if i was to switch to coilovers would that make it smoother and some suggestions on what brands?
Old Jun 2, 2009 | 11:02 PM
STOCK_SOHC_DX's Avatar
Default Re: coilovers
Coilovers don't fix this. Did you replace your struts?
Old Jun 2, 2009 | 11:23 PM
AP2FTW's Avatar
struts that can handle the spring rates would help
Old Jun 3, 2009 | 05:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The only thing that will make the ride smoother is to raise it up and use softer spring rates. If you're lowered quite a bit, the car will either bottom out, or the springs will be very stiff to keep it from bottoming out. Either way the ride won't be smooth at all unless the roads you drive on are super smooth.
Old Jun 3, 2009 | 07:41 AM
98civtec's Avatar
yuup thats what i figured ya but il probal just go with new struts and coiloveres just cause i hate to be stucj at a certain ride hieght
halloween_ninja
Jan 19, 2009 08:01 PM
theciv
Honda Civic (2001 - 2005)
Jun 18, 2008 08:55 PM
Civicta
Aug 3, 2003 11:39 AM
Aphrodavid
Nov 27, 2002 12:42 PM
Brett
Nov 23, 2002 12:41 AM
