91 ef SIR SWAP FUEL PUMP HELP
i have a 91 sir swap and my fuel pump is going bad, so I have an extra gsr fuel pump either obd1 or 2 but my car is obd0.. will the gsr fuel pump work or no?
will it work im pretty sure. fuel pumps work of a 12v source and a ground. will it fit im about 90% sure it will fit as long as you use your stock hanger assembly.
the gsr pump will work fine. I think you do need to soder some wires though as may not share the same type of connector.
civic are like 79lph and gsr/itr are like 139lph.. (I think...)
94civicdeleon
Jun 17, 2009 08:12 PM
bew
Aug 4, 2003 05:25 PM
714phil
15
Jun 29, 2002 08:25 PM
