Didn't pass Smog! Whats wrong??
Old Jun 2, 2009 | 07:50 PM
MUGEN_EG95's Avatar
Default Didn't pass Smog! Whats wrong??
I have a 95 honda civic ex vtech. I took it to a smog station and they said my hydrocarbon numbers are too high at 900 RPM. But it's fine at higher RPM! He said maybe vacuum leak or a tune up is needed. I do have a blown piston ring in number 3 cylinder though. Could this be the perp? I really need it to pass smog so help!!
Old Jun 2, 2009 | 07:52 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Didn't pass Smog! Whats wrong??
if you have low compression and are burning oil, that will make the hc's higher than acceptable.
what is the minimum, and where are you?
Old Jun 2, 2009 | 07:59 PM
MUGEN_EG95's Avatar
Man that sounds like the problem. I do have low comp and burn oil. My minimum is 100 and i'm at 322 in HC.
Old Jun 4, 2009 | 06:25 AM
Mr. Badwrench
only thing i can say is make sure the cat is good and hot. but if it is burning oil, you may have to start there.
wardseg6
Sep 15, 2016 08:52 AM
langjairicer
May 28, 2010 01:13 AM
JDMguy88
Oct 4, 2008 01:19 AM
RED DA
Nov 12, 2007 02:05 AM
Goy091
Apr 25, 2002 09:26 AM
