2-4K part throttle backfire at shift. Tuner advice
I know it's a fueling issue because if I shift fast or give it a tiny bit of throttle between shifts it doesn't happen.. but how rich can you get in vacuum and still have issues.. especially when you're cruising at high 13's AFR
I'm thinking the injectors might be at fault.
