Will 17x7.5 +48 fit on my teg with 2.5 drop?
Old Jun 2, 2009 | 12:26 PM
PaChiLa Leader's Avatar
Icon6 Will 17x7.5 +48 fit on my teg with 2.5 drop?
Wheel question
i would like to know if 17x7.5 +48 would fit on my teg
thanks
Old Jun 2, 2009 | 03:06 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Will 17x7.5 +48 fit on my teg with 2.5 drop?
I don't know for sure, but it will certainly depend on the tire size. 205/40-17 has the same outer diameter as the stock Integra GSR/ITR/SE tire size of 195/55-15, so don't get tires any bigger than that.
Old Jun 2, 2009 | 10:25 PM
thanks man.
yes the tire size is 205/40/17
reason why i am asking is coz these wheels i am interested in are out from SK2 so just want to make sure the offset would fit on my car that's all
anybody else??
Old Jun 3, 2009 | 05:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
+48 is a pretty high offset, especially for 7.5" wheels. I'm thinking you'll have problems with rubbing when turning, or very possibly it might rub the rear shocks. You may have to run a 5mm spacer or something.
Old Jun 3, 2009 | 08:27 AM
nsxtasy's Avatar
H-T Order of Merit
Also beware the difference in center bore (the diameter of the big hole in the center of the wheel, and the hub on which it is placed). The ITR has 64.1 mm at both ends; the S2000 is 70.1 mm at one end, 64.1 mm at the other. You'll want to get hubcentric rings for the wheels with the bigger center bore, to avoid problems with vibrations on the ITR.
The S2000 also uses different offsets, front vs rear; it's not clear whether that's the case with these wheels, or if the person is using spacers to adjust for the difference in offset.
In general, wheels from the S2000 and NSX are not a direct bolt-on for the ITR, and need some additional items to make them work (such as the spacers that Patrick mentions, as well as possibly extended studs and open-end lug nuts). I've tried, and found that it's a lot easier to just get wheels that are made for the ITR.
El3ments
Mar 13, 2009 11:36 AM
Robteg
14
Nov 21, 2008 12:10 PM
94 IntegraLS
May 18, 2007 03:26 PM
Blacklabel182
Jul 22, 2006 10:15 AM
mustninty
Apr 22, 2005 08:50 AM
