need abs removal help ASAP
Old Jun 2, 2009 | 11:31 AM
bdmlilburn's Avatar
Default need abs removal help ASAP
96 honda accord ex
last night i removed the abs system and installed a 93 accord master cylinder and proportioning valve i picked up from a pull a part. used the 93 accord drivers side brake line and a 51" line from autozone. there is no brake fluid leaking from any of the connections. the problem is there seems to be a vacuum leak somewhere around the master cylinder. with the car turned on you can hear an obvious leaking of some kind of pressure. the brakes also do not want to keep pressure. ive already bled all four wheels about 3 times each.
*note i used my old brake booster(abs version) with the non-abs master cylinder and proportioning valve
*also i havn't bench bled the booster or master. not exactly sure how to do this. would this help?
problems:
-no brake pedal pressure-no brake fluid is leaking at any of the new connections
-some kind of vacuum leak around the master cylinder
i really need to fix this. any suggestions on what my problem is? maybe still some air in the lines?
Old Jun 2, 2009 | 12:02 PM
Voodooboy520's Avatar
Default Re: need abs removal help ASAP
You'll definitely need to bench bleed it. The short version is that you take the master cylinder and run fluid through it till all the air is gone. You can't bleed the booster, there isn't any fluid in there :-p
Make sure you got rid of the old master cylinder gasket (between the master and booster), it could be causing the leak. Better yet, make sure you still have one.
Not sure why you removed the ABS, you could have just pulled the fuse...
Old Jun 2, 2009 | 12:13 PM
bdmlilburn's Avatar
ya ive already had the fuse pulled to see how it runs without the abs. and now my goal is to remove the abs components to clean up the engine bay. ya i removed the old gasket from the abs master cylinder and used the gasket from the non-abs accord. would not performing a bench bleed be causing my problem? if i bench bleed should i do that and then also bleed the calipers from longest to shortest again?
Edit: when the brakes are pumped with the car on the idle jumps from 1 to 1.5k. like it would if the fitv was being blocked. but the fitv is working proprly because it only does it when the brakes are being pumped
Old Jun 3, 2009 | 03:44 AM
Pumping the brakes will cause the idle to jump in any car that has vacuum assisted brakes.
If there is a ton of air in the master then yes, the pedal would just go to the floor as you compress the air.
Old Jun 3, 2009 | 07:54 AM
bdmlilburn's Avatar
i don't think air in the master is my problem. like i said before it sounds like there is a huge vacuum leak around the master/booster area. my freinds paps is tellin me that the master cylinder i got from the junkyard is probably no good. either that or the abs brake booster is not sealing properly with the non-abs master cylinder causing the vacuum leak.
when i turn the engine off you can still hear the vacuum leak for about 5 seconds and then it slowly stops
prelude5blue
Suspension & Brakes
Jul 2, 2014 08:43 AM
stevedefacto
Dec 25, 2011 06:04 AM
dailydrivenHONDA
Jun 8, 2009 01:16 PM
1992integra
Dec 21, 2008 06:04 PM
trborex
Jan 22, 2002 03:24 AM
