FS/FT 1993 honda civic hatch-10.76@126
NOT PARTING ANYTHING OUT....DO NOT ASK!!!!
Heres the rundown
Car:
93 Civic DX hacthback
Clean title
JDM thin side molding
Wing West RS side skirts
Dont remember the front lip
Carbon fiber hood (not in the best shape)
Relocated battery to the back (not a hack job)
Custom battery cutoff switch
Inside:
Sparco Rev seats on Sparco sliders
97 Integra rear seats
JDM center console
4-door elbow console
98 Prelude CD player
infinity reference door speakers
Auto-Meter Oil pressure
Auto-Meter Boost
Auto-Meter EGT
Innovate wideband
Unknown brand but rare bolt in roll cage
Walbro 255 in the tank
Motor:
AEBS Pro Sleeved B18A1 (closed deck) 83mm-Motor has less than 2000 miles on it.
Ross pistons
Pauter 4340 Crome moly rods
Z10 Girdle
ARP hardware through out
Type R Oil and Water pump
Brand new OEM honda timing belt
Brand new GSR oil pan
Arizona Race mounts
Head:
Brain Crower spring retainers and valves
Skunk2 Pro 1 cams
Skunk2 Pro Intake manifold
Skunk2 Pro Cam gears
Skunk2 Plug wire cover
Skunk2 Oil cap
Skunk2 Vtec solenoid cover
Vented valve cover
Endyne catchcan
BDL fuel rail
PTE 1000cc injector
Aeromotive A1000 fuel pressure regulator
Transmission:
'00 SI rebuilt tranny with new synchros and Quaiffe LSD
Golden Eagle scatter shield
ACT 7lb. Flywheel
XTD Stege 4 clutch (unsprung 6 puck)
Newer OEM axles
Suspesion/handling:
G.A.B. coil overs (height and dampening adjustable)
Rear lower control arms
ETD traction bar
'00 Si front strut bar
98 GSR rear disc conversion
Stainless brake lines on all 4 corners
Brembro slotted crossdrilled rotors (front)
EBC pads
Extended lug studs (some are broken but have a complete new set in the box)
Will come with an '01 Type R brake master cylinder (1")
OEM integra special edition wheels with 85% tires on all 4
Turbo:
AFI Top-mount (lifetme warranty) twin scroll T4
60-1 (Ebay) T4, good to over 600hp
Dual Tial 44mm wastegates with 21psi springs
4" Stainless exhaust through the hood (V-Band)
2.5" intercooler piping
Ebay BOV
Treadstone Intercooler
Tuning:
P06 Chipped for VTEC by myself
Moates Ostrich
Moates Hulog
Tuned on Crome Pro Gold base
Thats all i can think of right off the top of my head, im sure there are a few things im forgetting.
So far, the car has done a 10.76@126. I couldnt get it into 5th so i was basicly coasting from about the 1000ft mark. Moving the rev limiter from 8500 to 9500 and putting the 24.5" slicks on it will mean not having to get 5th till 145mph. I run 15w40 Synthetic oil in it and gets changed every month. Its on a VERY safe pump gas tune on 22psi and with more aggressive tuning and race gas over 600 is easy. Ive only made 12 or so passes in the car, the last 4 were on 23" slicks and spinning those in 1st and a little in 2nd. On drag radials it was spinning all the way down the track and trapping 131mph!
No leaks, no drips, no surprises
TRADES: Open to just about anything performance oriented, would like something turbo'd. NO TRUCKS, SUV'S, LOWRIDERS OR ANYTHING LIKE THAT!!!!
stubbysq@yahoo.com
509-496-8108
Heres the rundown
Car:
Clean title
Inside:
JDM center console
Auto-Meter Boost
Auto-Meter EGT
Innovate wideband
Motor:
Ross pistons
Z10 Girdle
Arizona Race mounts
Head:
Skunk2 Pro 1 cams
Skunk2 Oil cap
Vented valve cover
Endyne catchcan
BDL fuel rail
PTE 1000cc injector
Transmission:
ACT 7lb. Flywheel
Newer OEM axles
Suspesion/handling:
ETD traction bar
EBC pads
Turbo:
Ebay BOV
Tuning:
Moates Ostrich
Moates Hulog
stubbysq@yahoo.com
509-496-8108
thanks for busting my ear drums at the summer seattle meet when you were bouncing off the rev limiter. Haha JK that is one sick car. I wish I could afford it.
a1320honda
Northwest (Sales)
Apr 13, 2009 02:26 PM
