Ive just fitted discs all round, how can I get ABS to work? EG civic
Hello guys, I used to have drum brakes on the rear and 242mm discs on the front. Ive just switched to a VTi setup so now have discs all round and slightly bigger 262mm up front. There are orange plugs which are hanging from each corner, does anyone know how I can wire them up so ABS works? This is for a 94 EG civic hatch
Thanks in advance
Thanks in advance
you need the whole ABS assembly... it not just a matter of connecting wires to your existing set-up. Your car didnt come with ABS so you need to gather all ABS system items then install in your car...good luck
Cheers for the reply, it didnt come with ABS but I can grab the bits off the car I got the brakes from then go from there. I guess it should be all in the manual somewhere
