Crower Valve adjustment questions?
Old Jun 2, 2009 | 02:31 AM
jdmboy94's Avatar
Default Crower Valve adjustment questions?
well i got a ls with a full crower head assembly. it has the crower 404s in it, i need to adjust the valves. do i do them to stock ls specs or something different? and does the motor need to be cold when adjusting the valves or hot? ive heard it needs to be cold? thanks
Old Jun 2, 2009 | 04:33 AM
kyden's Avatar
Default Re: Crower Valve adjustment questions?
has to be cold. i'd call crower and ask them for lash spec.
Old Jun 2, 2009 | 04:48 AM
GhostAccord's Avatar
Valve lash is set with the engine cold and the Crower specs are as follows,
Originally Posted by Crower.com
Note: These cams use .006" intake (cold), .008" exhaust valve lash (cold).
or you could go to the website and see the spec PDF.Click here!
ssmrico
Mar 4, 2012 03:56 PM
DA_JDM
Aug 24, 2007 01:17 PM
prelude1897
Jun 26, 2005 01:58 PM
06Xrunner
Nov 5, 2002 05:58 PM
3rdGteg
Apr 22, 2002 02:16 PM
