zc turbo
Old Jun 1, 2009 | 11:44 PM
crex-ef's Avatar
Default zc turbo
hey to all, i just got an SI crx with a zc vtec obd0 status. and i just came across another zc non vtec which is still obd1 i was told to get a jumper harness to fit the ecu.not sure if thats all that im going to need. since the old motor is vtec am i going to have to cancel any wires or wat?? also with used turbos what should i clean it with what precaution should i take before installing thanxx
Old Jun 2, 2009 | 04:43 AM
dephtone's Avatar
Default Re: zc turbo
As far as the motor goes, you will have 2 plugs left over, VTEC solenoid and Oil Pressure switch. For the obd1 non vtec depending on if you want to stay obd0 or go obd1.
If you want to stay obd0, just use an obd-0 distributor and ecu and be done or if you want to go obd-1, obd1 distributor, conversion harness, distributor conversion harness, and obd-1 ECU.
On the outer covers i used Mean Green from like the dollar store, made it clean up real nice.
Old Jun 3, 2009 | 12:15 AM
crex-ef's Avatar
thanx what about the turbo
Old Jun 3, 2009 | 05:23 AM
dephtone's Avatar
As for precautions make sure there is no excessive shaft play, up and down and side to side. If there is an excessive mount the turbo will end up hitting the compressor cover and possibly seize from hitting the alum housing. At that point you can have it rebuilt if it's a garrett or another name brand and not the ebay kind either.
KevinEF7
Oct 29, 2012 01:15 PM
madmike84
13
Jul 11, 2009 07:44 AM
axionm1k
May 23, 2007 04:20 AM
Angry
May 5, 2006 08:58 AM
crxzcracer
Mar 2, 2005 03:39 PM
