have a tire question from a non H-T person.
Old Aug 19, 2002 | 05:56 PM
Bbasso's Avatar
Default have a tire question from a non H-T person.
on a ITR which one of these tires will fit the best (with out any rubbing or headaches)?
*stock suspension*
205/45R16
215/45R16
225/45R16
225/40R16
all on:16"x7.5" Wheels.
thanks.
Old Aug 19, 2002 | 06:37 PM
Dodger2940's Avatar
Default Re: have a tire question from a non H-T person. (Bbasso)
Here is a cool Tire Diameter Calculator that might help you out.
http://www.we-todd-did-racing.com/we...EzZGZkMzF5NTQx
It is an Excel file.
Old Aug 19, 2002 | 06:40 PM
Reid's Avatar
Global Moderator
It really depends on wheel offset and tire choice,
But if you want to be 100% safe go with the 205/45/16 tires.
I'd venture to guess one of the only 215/45/16 tires to have rubbing issues would be Falken Azenis, but again this all depends on wheel offset.
Old Aug 19, 2002 | 06:43 PM
George H's Avatar
Yes, the 205/45/16's will provide the least percentage of error from stock.
This will help http://www.miata.net/garage/tirecalc.html
The tire size calculator on the bottom of the page will allow you to see how much of a percentage error your new tire size is from stock. The lower the percentage of error, the better.
Just as a reference point, 205/45-16 is 0.8% off from stock, which is not bad at all.
[Modified by KANJI, 7:47 PM 8/19/2002]
Old Aug 19, 2002 | 06:45 PM
Bbasso's Avatar
Default Re: have a tire question from a non H-T person. (Reid)
thanks, I passed on the info . thanks.
Old Aug 19, 2002 | 11:02 PM
Mr. Choi's Avatar
New User
let me add those tire cacluators arent as accurate as they should be. the circumferance from different manufactures will differ even with the same tire size. although very simlar. take it into consideration when buying different size tires from different brand.
BB1LOViN
Dec 20, 2007 04:46 PM
betta285
May 14, 2007 06:10 AM
pyitrboy
Jan 10, 2007 05:11 PM
dads_fast_ek
May 17, 2005 06:24 AM
Mr. Vapor
Jul 1, 2002 11:23 AM
