dc5/ep3 ecu question
Old Jun 1, 2009 | 07:28 PM
blkekcoupe's Avatar
Default dc5/ep3 ecu question
will the ep3 ecu run in a rsx base....they both run the A3, only issue i see is that the ep3 uses EPS(electric power steering) and the rsx does not. also that the ep3 has the metal manifold and the rsx base has the plastic, so i was wondering in putting an RBC mani with the ep3, which i assume the ecu gets rid of the dual runners the base rsx uses. can anyone chime in if this will work thank you in advance
Old Jun 1, 2009 | 09:18 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: dc5/ep3 ecu question
Well it will run lean with the RBC. Why can't you find another base RSX ecu? What happened to yours?
Old Jun 2, 2009 | 04:55 AM
turboteg2nv's Avatar
If you're going to install an RBC manifold, just buy Kpro too.
01_CivicEM2
Honda Civic (2001 - 2005)
Sep 12, 2011 11:23 AM
m.kusanagi
17
Jan 21, 2009 09:31 AM
billybong91DA
Feb 1, 2004 01:53 PM
preludacris
May 12, 2003 05:41 PM
