Suspension & Brakes Theory, alignment, spring rates....
Problem with rear brakes 95 accord ex
Old Jun 1, 2009 | 06:58 PM
thebobrusso's Avatar
New User
Icon6 Problem with rear brakes 95 accord ex
Changed rear pads and rotors on both sides, replaced passenger side caliper with refurbished one, bled the whole system including front brakes, now brake pedal goes to the floor, sytem is not leaking only thing I could come up with is the refurbished caliper is defective, any advice, please help...
Old Jun 8, 2009 | 10:57 AM
GSRShane's Avatar
Default Re: Problem with rear brakes 95 accord ex
Assuming that the bleeding was done properly (ie you kept brake fluid in the master cylinder reserve the whole time and you're sure all the air is out) and you are not leaking fluid . . . I'd have to say your brake booster/master cylinder is shot. Do you loose brake fluid over time? If not there is really no other explaination.
alferz
May 24, 2012 01:09 PM
hurrcane201
Aug 1, 2006 07:04 PM
SneezinCD5
Nov 20, 2005 03:01 PM
Next GenRacing
Jun 20, 2005 05:12 AM
wra10s
Aug 31, 2001 06:22 AM
