Ground Control srping rate + Tokico Blue
I was going to pick up gc + tokico blues
dude said front spring rate was 250 and rear
was 180. How would this ride with the tokico blues?
like shAt... HP's will blow out in short order. They just cannot handle stiff spring rates or riding low. Should have gone with Illuminas as a minimum for GC's.
If you use the lower perch settings with aftermarket lowering springs, though, the front end is liable to be damn near on the ground, and the rear not so much. I'm using stock GS-R springs up front and stock ITR springs in the rear on the lower Koni perch setting all around and it sits and rides nice.
Your best bet, though, would be to go with Koni + Koni-specific GC sleeves. Then you have total ride height control.
MrOsvaldo221
Suspension & Brakes
Nov 29, 2013 12:51 AM
