question on running 8 injectors
Old Jun 1, 2009 | 04:08 PM
TokuiAutowerks's Avatar
Default question on running 8 injectors
does anyone know if hondata can run 8 injectors? or am i going to have to switch over to AEM EMS?
Old Jun 1, 2009 | 08:02 PM
locash's Avatar
Default Re: question on running 8 injectors
If you have 8 decent high impedance (saturated) injectors, yes, you can do it a few different ways.. You can run all 8 in parallel, or run all 8 in parallel with the power for the second set off of a decent relay set up to turn on with vtec via an aux output from the ecu.. I have done it both ways on more than a few cars now (using the 1000cc Injector Dynamics injectors), with no problems..
Old Jun 1, 2009 | 09:09 PM
currently im running 4 PTE 1600cc peak n hold injectors. is there a set up i can run another set of peak n holds like the saturated injectors?
Old Jun 1, 2009 | 10:43 PM
mtber's Avatar
I would suggest running 8 of the high impedance injector dynamics 1000cc injectors.
Old Jun 2, 2009 | 09:51 PM
locash's Avatar
You could probably do it using an FJO or AEM injector driver box, but the 1600cc injectors are such pieces of ****, that it makes sense to just get rid of them altogether.. To be honest, I haven't been impressed with any injector sold by Precision, they seem to use the cheapest crap they can get, and don't bother matching them at all..
sevenj
May 21, 2008 04:50 PM
Justin Olson
Mar 22, 2006 07:52 PM
underpressure02
Feb 1, 2006 03:27 PM
fortynineR
Jul 23, 2002 07:21 PM
fortynineR
Jul 23, 2002 05:47 PM
