D-15/16 AND B-SERIES SIMILARITIES?
I WAS WONDER WHATS INTERCHANGABLE BETWEEN TRANSMISSIONS AS FAR AS:
REVERSE SENSOR- ARE D AND B MANUEL INTERCHANGABLE?
SPEED SENSORS- " "
LS SPEED GEAR IN GSR? NOT SURE ON OBD
ALSO WHEN PUTING A LS FINAL GEAR IN A GSR TRANNY DO YOU NEED BOTH INPUT AND COUNTER SHAFT GEARS OR JUST ONE? THANKS MUCH
SPEED SENSORS- " "
If the thread pitch is the same, they 'should' be.
The holes will more than likely line up in order to bolt them into the trans, but have no clue on if the speed sensors gear pitches, teeth count, and height are the same between them.
Hydro gears will fit the hydro transmissions. 92-93 cable trans will also work. You need both counter shaft and main shaft gears for the swap.
Originally Posted by grant97teg
SPEED SENSORS- " "
C Rex Express
Transmission & Drivetrain
Jan 23, 2014 07:54 PM
