95 Civic hatchback FS
I got a 95 Civic hatchback for sale .
Location Coral springs.
swapped the head so its now a mini me, also changed the head gasket
y8 manifold
new starter motor
new spark plugs and wires
just changed the dizzy so it throws no codes
just changed the cluster so it now has RPM gauge
has a 3 point upper strut bar and a 2 point upper rear strut
changed the muffler to quiet it down, should still have old muffler if you want
it
comes with lower springs 6 all together, 4 matching , 2 matching , fronts have a coil overs but struts need to be replaced.
comes with a new brake booster, havent had the time to install , still in box
has everything you need for a/c accept compressor and belt
needs inner and outer tie rods
no radio, no ps, glass all around is good, windows roll up and down fine, Motor runs good no overheating problems , no rust, or anything, just needs suspension and paint job, its in black primer.
$2500 obo
y8 manifold
new starter motor
it
$2500 obo
akirab16
Oct 29, 2004 08:01 PM
darby133
Jul 26, 2004 03:51 PM
