HELP! 06 type s BAD CLUTCH?
Old May 31, 2009 | 10:07 PM
06typeSEX's Avatar
Default HELP! 06 type s BAD CLUTCH?
Is my clutch done? or what is the cause of the problem? I have about 95*** and today I try pulling out of my garage. The clutch pedal was just stuck to the floor, I had to pry it back up. It didnt want to go into gear and I stall about 10 times trying to go back into my garage. HELP PLZ!
Old Jun 1, 2009 | 12:42 AM
vladd's Avatar
Default Re: HELP! 06 type s BAD CLUTCH?
is there fluid in the clutch resevoir? when the pedal's sinking to the floor it's usually cuz there's no fluid, not cuz the clutch is bad.
Old Jun 1, 2009 | 01:15 AM
mannydc5's Avatar
Sounds like what happened to me except i got the clutch pedal to pop back up. it would smell like burnt clutch and when i would pressed the clutch i would make a horrible sqeecking sound.
Old Jun 1, 2009 | 06:52 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
sounds like a different problem. Have you had any slipping issues before? Like on the interstate notice your RPMs shooting up but not your speed?
Old Jun 1, 2009 | 08:00 AM
sicky's Avatar
grammer nawzi
master cylinder or slave.
Old Jun 1, 2009 | 08:14 AM
06typeSEX's Avatar
Nope it never slip before, im gonna head to GM and pick up some syco mesh fuild to see how that goes.
Ill check out the master cylinder. What should i looked for? cracks? leaks?
Old Jun 1, 2009 | 08:50 AM
josh's ep3's Avatar
Function > Form
You just need brake fluid to add into the clutch res., the same dot-3 that goes in the brake res. Topping off your tranny won't do anything if it's the clutch.
Old Jun 1, 2009 | 09:38 AM
06typeSEX's Avatar
Yea I check the Clutch res. and its low. So, im walking to the nearest auto store lol. Which is about a mile away
Old Jun 1, 2009 | 10:48 AM
06typeSEX's Avatar
I top off the clutch res. and it works but it feels like the clutch pedal has play, doesnt feel the same way.
Old Jun 1, 2009 | 11:38 AM
prejdmlude's Avatar
bleed the line
Old Jun 1, 2009 | 12:20 PM
josh's ep3's Avatar
Function > Form
Word ^
Old Jun 1, 2009 | 12:46 PM
06typeSEX's Avatar
This might sound stupid but where is the bleeder valve! I looked everywhere on the transmission lol
Is there a DIY thread? and Thanks everyone you guys been real helpful!
Old Jun 1, 2009 | 02:12 PM
06typeSEX's Avatar
Thanks everyone AGAIN! Car is running good.
The bleeder valve was hidden behind my CAI lol
hannslebo
Mar 24, 2009 01:53 PM
integragsssr
Feb 6, 2009 08:54 PM
sibious
Jun 13, 2008 03:53 PM
Lb1atx
Sep 7, 2007 05:16 AM
amerikinjesus
Apr 9, 2004 11:52 PM
