bad wheel bearing on a 01 accord
Old May 31, 2009 | 04:33 PM
gnx547's Avatar
Default bad wheel bearing on a 01 accord
I have an 01 accord and the driver rear wheel bearing is bad. Is the bearing pressed on? Or is it a whole hub assembly?
Old May 31, 2009 | 09:41 PM
YeuEmMaiMai's Avatar
Default Re: bad wheel bearing on a 01 accord
that bad boy is pressed on. you can press out the old one and press in the new one
Old Jun 1, 2009 | 11:30 AM
pickleboo's Avatar
just replace the whole bearing hub won't cost you that much instead bothering your self with the press.
Old Jun 1, 2009 | 11:43 AM
GhostAccord's Avatar
The rear hub & bearing assembly are sold as a unit.
Disk brakes
Honda Part number 42200-S84-C52
Drum brakes
Honda Part number 42200-S84-C01
Old Jun 1, 2009 | 06:47 PM
Blamm!!'s Avatar
yeah just replace the hub assembly, its easy I had both my rears go bad at the same time
Kevs02Accord
Dec 2, 2014 09:01 AM
PaChiLa Leader
Feb 18, 2009 05:21 PM
Nisif
Dec 4, 2006 04:03 AM
Old Skool
Sep 24, 2004 09:41 AM
Old Skool
Feb 21, 2003 12:13 PM
