92 accord lx no start
Old May 31, 2009 | 02:24 PM
ef-hatchcrap's Avatar
Default 92 accord lx no start
Well my wifes dad just picked up a free 92 lx its been sitting for 2 years not running. So I drag to my house check fuel,spark, all the necessities to run. Go to start it and nothing I wants to start run but kust wont. Fuel pump is priming everything is working what else should I check. Im new to accords but not hondas.
Old May 31, 2009 | 03:21 PM
Default Re: 92 accord lx no start
Ok so I jumped the service connector to see if it was throwing any codes and it just throws a solid cell. The check engine wasnt on I was just checking for intermittent problem codes
Old May 31, 2009 | 03:47 PM
Targa250R's Avatar
be professional
How did you check for fuel and spark?
Did you run a compression test?
Have you checked to make sure the ignition and cam timing are set properly?
Have you put fresh fuel in the car and/or cleaned the injectors?
mete4d
Jan 19, 2018 12:23 PM
surfhound
Dec 3, 2013 08:49 AM
92_Accord_LX
Nov 13, 2009 05:13 PM
jarymane81
Feb 10, 2009 02:35 PM
