FS: 3" Ek coupe exhaust w/ magnaflow muffler
Old May 31, 2009 | 11:58 AM
EJ8chu's Avatar
Default FS: 3" Ek coupe exhaust w/ magnaflow muffler
I'm selling my old exhaust. I had this on my coupe when it was turboed. Its pretty much an off brand 3" exhaust that i cut and extended the front to act as a replacement for the test pipe, and cut the muffler and replaced with a Magnaflow 3" straight through. It was fairly quiet cruising. Its a little scraped up and the welds aren't the best but it works and doesn't rub the car or sway bar if you have one. The piping was all polished so i sprayed it with DEI header paint that is now chipping because i didn't prep it at all. It would all pressure wash off. It includes the 2 gaskets that go on the piping and all hardware. I have a 3 bolt gasket for the front that would work, but its kinda beat. The resonator had scraped through, so a a crappy weld was layed down to keep it from starting to leak. It works fine and hasnt progressed.
Im asking 200 picked up. If you want it shipped, let me know and ill see what i can do at your expense.
Old May 31, 2009 | 06:05 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: FS: 3" Ek coupe exhaust w/ magnaflow muffler
Bump sounds good!
Old May 31, 2009 | 07:21 PM
b16ajdmrex's Avatar
where in MD r u located?
Old May 31, 2009 | 08:08 PM
EJ8chu's Avatar
In the middle. PM me if your serious
Old Jun 3, 2009 | 06:29 PM
EJ8chu's Avatar
ttt
Old Jun 3, 2009 | 06:30 PM
EJ8chu's Avatar
200 picked up is on the cheap.
Old Jun 4, 2009 | 12:53 AM
joe0522's Avatar
would you sell the axle back bro? pm me if you will .
Old Jun 4, 2009 | 04:56 PM
EJ8chu's Avatar
I might, PM me with an offer shipped
Old Jun 6, 2009 | 07:14 PM
97civic_coupe's Avatar
did you ship the injectors? sorry for trolling but i need it, and your not answering pm's
Old Jun 7, 2009 | 11:08 PM
pm me you scammer, you scammed me out of some injectors and another guy from a map sensor
KangBanger
Oct 24, 2010 05:05 AM
jwcok20em2
Honda Civic (2001 - 2005)
13
Aug 4, 2008 12:20 PM
atc5
Jun 15, 2004 01:19 AM
