Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Girl in need of help, Will 2008 SI Sway bars fit a 2008 LX ??
Old May 31, 2009 | 08:15 AM
diamondflaw2005's Avatar
Default Girl in need of help, Will 2008 SI Sway bars fit a 2008 LX ??
As the title says, my car is currently sloppy as hell on the road, feels like a minivan. So i want to put sway bars on but i noticed they are only made for the 08 si, does anybody know if they can fit an 08 LX ?
And also does anybody know where to get the F/R set thanks.
Old May 31, 2009 | 08:16 AM
Default Re: Girl in need of help, Will 2008 SI Sway bars fit a 2008 LX ??
xEdit, the car is an LX Coupe, sorry about that
Old May 31, 2009 | 08:20 AM
teggsr925's Avatar
they will fit, the suspensions are interchangeable, but u might need si endlinks, but im not sure.
im sure somebody knows
Old May 31, 2009 | 08:21 AM
Awesome, do you know where to find some, i found them on modacar but is there on other sites, personally im most familiar with dsms so yea lol thanks for the infos.
Old May 31, 2009 | 08:22 AM
teggsr925's Avatar
procivic.com
importdpsonline.com
corsportusa.com
evasivemotorsports.com
Old May 31, 2009 | 08:25 AM
Thanks alot.
Old May 31, 2009 | 08:36 AM
http://importdpsonline.com/eibach/ei...0/i-54104.aspx
Im looking at that right now, that will fit the car correct i know it says it does but i just wanna make sure, thanks.
Old May 31, 2009 | 08:47 AM
teggsr925's Avatar
yea it will
Old May 31, 2009 | 09:12 AM
K5^'s Avatar
K5^
Brand New
I have a full oem si suspension for sale also if you're interested.
Old May 31, 2009 | 10:20 AM
2008fijibluesi's Avatar
Honestly, if a 2008 Civic (no matter what model) is that sloppy on the road, there is probably something wrong. There is a difference between the LX and Si, but the LX still handles a lot better than a minivan. Maybe you should make sure something isn't broken first.
Old May 31, 2009 | 09:42 PM
Well comparing to my bf 1998 talon tsi awd that handles on rails its a minivan lol, but it handles alright however not as good as i want it to, and btw it has 19k on the odo.
Old Jun 1, 2009 | 04:12 PM
byronl's Avatar
hey i did this to my 08 lx sedan. You're gonna need the swaybar assembly, si endlinks, and big brackets that mount the swaybar to the chassis of the car.
Old Jun 1, 2009 | 06:42 PM
Cool, may i ask how your car felt after you did the swap ?
Old Jun 1, 2009 | 08:23 PM
byronl's Avatar
Noticeable Difference! Mind you that I only upgraded the rear swaybar and the car rotates in so much better than it did before. The understeer went away, more neutral feeling. The body roll also has reduced alot too. It's worth it.
Old Jun 1, 2009 | 09:23 PM
Awesome lol thats what i want, 0 bodyroll hehe, my plans are SI sway bars, strut tower bars and most likely SI shocks/springs and i believe that should do it. My question is how hard was it to do the install pretty easy right ?
Old Jun 1, 2009 | 09:30 PM
K5^'s Avatar
K5^
Brand New
When swapping out the strut and springs the most time consuming part is assembling the strut/spring unit. But if you go with a fully built oem si suspension, the fronts go in in 45 minutes or less (with two people). The rears take some more time. Getting access to the top of the rear struts requires that you remove all of the trunk lining, while also dismantling part of the trailing arms to free up the old rear struts. Since you're probably going to replace the sways at the same time, it should go a lot smoother. The rear sway gave my friend and me some trouble when we firsted jacked up the back end.
Old Jun 1, 2009 | 11:59 PM
av911's Avatar
From what I've read, putting an Si suspension will raise the car of an R18.
http://www.8thcivic.com/forums/civic...-complete.html
Old Jun 2, 2009 | 03:04 AM
Kidnkorner's Avatar
The rear Si sway is the only one you want, forget about the front! I swapped my front Si bar for a LX/EX unit.
Old Jun 2, 2009 | 09:41 AM
teggsr925's Avatar
no its drops it like half an inch
Old Jun 2, 2009 | 08:08 PM
Why do you say forget the front ?
Oh and thanks for the response K5^, and tegg, very much appreciated.
Old Jun 2, 2009 | 08:54 PM
Kidnkorner's Avatar
you want your car to have an easier time cornering and keeping the stock up front with the Si out back will reduce understeer, much like Si owners upgrade their rear unit. Little did they know they could have swapped in the LX/DX front and save a grip of cash.
Old Jun 2, 2009 | 08:59 PM
Hmm so OEM LX front and SI rear ?
Old Jun 2, 2009 | 09:03 PM
Kidnkorner's Avatar
10-4
Old Jun 2, 2009 | 09:08 PM
K5^'s Avatar
K5^
Brand New
A front biased functional stagger of the wheel-tire combo has a similar effect.
Old Jun 2, 2009 | 09:19 PM
10-4?? whats that ?? im a lil lost...
