APEXI ECV 80MM BRAND NEW IN BOX!
The A'PEXi ECV - Exhaust Control Valve - allows you to control the loudness of your exhaust sound. The ECV is installed right after the catalytic converter
, and adjustment of the valve is done through a cable run from the cockpit to the valve body. All you have to do is slide the lever installed in the car to get the appropriate sound. With the A'PEXi ECV you'll no longer need to get out of the car to fit a detachable silencer into the tail pipe.
This is 100% authentic APEXI product, brand new in the box. 80MM size flange style.
$130 Shipped in the USA and CAN
, and adjustment of the valve is done through a cable run from the cockpit to the valve body. All you have to do is slide the lever installed in the car to get the appropriate sound. With the A'PEXi ECV you'll no longer need to get out of the car to fit a detachable silencer into the tail pipe.This is 100% authentic APEXI product, brand new in the box. 80MM size flange style.
