car idle funny after valve adjustment................
Old May 30, 2009 | 05:38 PM
Ruben19's Avatar
Default car idle funny after valve adjustment................
i have blox type b tuner series cam & i adjusted my valve to stock specifications. .006-.007 intake & .007-.008 exhaust. today i drove the car & the idle started going up & down(sometimes). do i have to adjust my idle screw as well?
Old May 30, 2009 | 11:14 PM
Ruben19's Avatar
Default Re: car idle funny after valve adjustment................
come on guys. is the all motor section. someone gotta know...
Old May 31, 2009 | 01:11 AM
Rocket's Avatar
Is the motor "throttling" (rpms swing between 800 and 2000 rpms) or you have weak idle like the motor is almost stalling?
Old May 31, 2009 | 01:47 AM
Ruben19's Avatar
weak idle.
Old May 31, 2009 | 02:01 AM
superman1987's Avatar
New User
Default help plzzzzzzz
hi i hav a r33 gtr v spec im trying to find the boost control solenoid can any1 help or have a pic of where it is?
Old May 31, 2009 | 02:14 AM
Combustion Contraption's Avatar
Default Re: help plzzzzzzz
Old May 31, 2009 | 02:34 AM
Rocket's Avatar
Check lash, some might be tight.
Old May 31, 2009 | 06:27 AM
mtber's Avatar
Sounds like a tuning issue to me. Take the car to your tuner & have him double check the tune.
Old May 31, 2009 | 08:55 AM
Ruben19's Avatar
valve lash is fine.
i double checked everything.
it was idling fine before
Ruben19's Avatar
dude make your own thread
Old May 31, 2009 | 10:05 AM
omniman's Avatar
that would cost money and therefore is against ht code of ethics. the remedy must be free to solve.
Old May 31, 2009 | 10:17 PM
anothersickhatch's Avatar
if the idle was fine before, it's obviously something that you did to change it. i would pull the valve cover off and re-measure everything with your feeler gauge. something is off. i know that a smaller valve lash causes a low idle.
Old Jun 1, 2009 | 12:15 AM
DB2-R81's Avatar
25 Year Member
How valuable to observe your utilization of those 15 years of experience offering indispensable suggestions analogous with the objectives of a shared forum, sure fire way to sell more omni junk parts.
To the original poster, what have you checked over? What is your vacuum reading at idle?
Old Sep 2, 2009 | 09:07 AM
unique ej8's Avatar
New User
yea my idle lik real mean itll strt @ 2000rpm den go up n dwn 2 1000rpm n itll jst keep on doing that how do i fix that
Old Sep 2, 2009 | 09:18 AM
KYSI's Avatar
Nil Desperandum
Oh yea I forgot why I stopped posting/ reading in here. Thanks
xlusiveracer
40
Jan 23, 2017 09:32 PM
turbodailydan
Oct 22, 2009 12:48 PM
thunderboy
Jan 27, 2008 10:24 AM
redferio
12
Nov 5, 2006 06:00 PM
Hondapreludeg
Nov 23, 2005 05:03 PM
