JDM ITR throttle body.....
Old Aug 19, 2002 | 03:07 PM
Comp97GSR's Avatar
Default JDM ITR throttle body.....
Does anybody know if the USDM ITR t/b gasket will work with my JDM ITR t/b? Thank you for any insight.
Old Aug 19, 2002 | 03:08 PM
sgT's Avatar
sgT
Default Re: JDM ITR throttle body..... (Comp97GSR)
same thing so yes
Old Aug 19, 2002 | 03:10 PM
Comp97GSR's Avatar
Default Re: JDM ITR throttle body..... (sgT)
Thanx sgt!!
Old Aug 19, 2002 | 03:12 PM
Majuniors_no_vtecfu's Avatar
it should work
Old Aug 21, 2002 | 04:27 PM
Comp97GSR's Avatar
Default Re: JDM ITR throttle body..... (Majuniors_no_vtecfu)
Just incase some other H-T members are thinking of buying a JDM ITR t/b, the USDM gasket will not work with it. On the bottom side of the t/b the gasket leaves about 1/2 inch section expose the the outside world. Does anybody have any idea where I could get a JDM gasket? The GSR gasket comes close but I think it leaves a port underneath the t/b half exposed. Thank you.
Old Aug 21, 2002 | 04:29 PM
stick's Avatar
just use honda gasket sealant instead
Old Aug 22, 2002 | 05:55 PM
Comp97GSR's Avatar
Default Re: JDM ITR throttle body..... (stick)
Thanks, I have already thought of Hondabond,but since I need to drive my car everyday there is no time for setup and that there is a vacuum port that I don't know if it just needs plugging or if it should vent in to the t/b port I think I will try and do it right. Anybody know where I can buy one?
DeCoY
Aug 25, 2011 09:05 PM
autoxthis
Jul 25, 2008 09:34 PM
TheGSRGuy
Sep 2, 2007 05:43 PM
blackoutcivic
May 10, 2006 04:08 PM
ringgold
Jun 4, 2005 09:27 PM
