are crower cams & brian crower cams the same or are they different?
Old May 30, 2009 | 12:23 PM
vtec4deaththo's Avatar
Default are crower cams & brian crower cams the same or are they different?
whats the difference between the stage 2 cams from crower and brian crower? which one is better for an all motor h22a1 with type s pistons? whats the pro and conss for both these cams?
Old May 30, 2009 | 05:45 PM
xenocron's Avatar
Default Re: are crower cams & brian crower cams the same or are they different?
Brian Crower broke off a while back to concentrate on Sport Compact applications...they are not the same company.
Old May 31, 2009 | 11:06 AM
H-EK22's Avatar
there different... I ran BC 3's on a jdm h22a wit type s pistons...
Old May 31, 2009 | 02:53 PM
which company has a more reliable camshaft set?
Old May 31, 2009 | 02:57 PM
H-EK22's Avatar
I'd say BC... they stoped making crower cams while back...... while BC is still in production an still widely used..
Old May 31, 2009 | 03:49 PM
Natural Aspirations's Avatar
Really?
http://crower.com/cat/import/honda/cams/b_vtec.shtml
I believe Crower still makes their own cores where as BC buys them from the same place as some other manufacturers do.
Old May 31, 2009 | 04:33 PM
H-EK22's Avatar
Originally Posted by Natural Aspirations
Really?
Nice
Old May 31, 2009 | 09:13 PM
Scott_Tucker's Avatar
Is Brian Crower Bruce Crower's son or some other relative?
Old Jun 1, 2009 | 05:26 AM
so which company has a more reliable camshaft set?
Old Jun 1, 2009 | 05:39 AM
turbociv910's Avatar
Yes, His son.
Old Jun 1, 2009 | 05:46 AM
JDogg's Avatar
i wouldnt call one more reliable than the other.
I have used both with good results.
actually the only BC cam i have had issues with was the LS turbo cams. their springs bound up really bad, ended up trashing the setup and putting a vtec head on it.
Old Jun 1, 2009 | 07:58 PM
H-EK22's Avatar
You sure it was because of the cam itself? My buddy just had me order a set of those for his LS turbo on 14psi.....
Old Jun 2, 2009 | 06:25 AM
JDogg's Avatar
not sure if it was the cam or the spring, but it had BC everything, valves, springs, retainers, cams.
We didnt mess with it enough to find the exact cause. when we were rotating it over by hand after the install it bound up so hard that it cracked a cam cap.
we took it all apart, sent it back and put vtec on it.
interestingly enough, with the ls head it made 295hp at 11lbs, with vtec it made 360 at 11lbs! stock b16 head, with omni springs/retainers. stock valves, stock b16 cams, stock b16 intake manifold.
Old Jun 2, 2009 | 06:58 AM
kyden's Avatar
i had bc ls turbo cams and crower valvetrain and didn't have any problems. so maybe it was the springs?
Old Jun 2, 2009 | 08:11 AM
flippin86's Avatar
Both of these companies have respectable history but I've seen bcs cams break while instalation but this was on an sr20 motor I haven't seen any honda cams from crower or brian crower snap but bc has great customer service they gave us new ones with out returning the snapped ones
y-49
Apr 6, 2008 04:03 PM
