Suspension & Brakes Theory, alignment, spring rates....
kg/mm to lbs/in
Old May 30, 2009 | 03:41 AM
NlCK B's Avatar
Default kg/mm to lbs/in
here is a chart on the conversions
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
or you can just type it in to google like so (just fallow the link)
http://www.google.com/search?num=100...in&btnG=Search
Old May 30, 2009 | 06:21 AM
DEIVIONCRX's Avatar
Default Re: kg/mm to lbs/in
Or you can just divide or multiply by .0179
Old May 30, 2009 | 02:51 PM
xd69's Avatar
Or my favorite is to use this:
http://www.hraefn.net/projects/spring_rates.php
Converts between all spring rate formats
Old May 31, 2009 | 09:35 AM
Tyson's Avatar
i just use google.
http://www.google.com/search?hl=en&q...US316&ie=UTF-8
Old Jun 1, 2009 | 05:41 AM
JDogg's Avatar
multiply kg by 56 to get lbs
Old Jun 1, 2009 | 05:49 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It makes a difference you know, whether you divide or multiply. Divide 500 lb/in by .0179 and see what you get.
This.
B_Swapped93
Jan 7, 2014 05:06 AM
civickid03
May 23, 2007 07:59 PM
Flux
Jan 29, 2002 02:31 PM
