Transmission & Drivetrain Gearboxes, Differentials, Clutches
L3 cusco lsd
Old May 29, 2009 | 11:57 PM
usmcpab's Avatar
Default L3 cusco lsd
So I got a L3 Cusco clutch type lsd that I was able to swap into mt S40 B000 tranny. My question now is what type of axles should I use? Any help or insight is greatly appreciated. Thanks in advanced.
Old May 30, 2009 | 03:33 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: L3 cusco lsd
stock axles, but did you grab the speedo shaft?
If not, it's gonna cost you about $100 to get it, from Japan.
Cusco and Kaaz use the same speedo drive, cannot use OEM.
Old Jun 5, 2009 | 09:33 AM
usmcpab's Avatar
forgot to mention that the stock axles didnt work. d16 axles were a bit small. my B series axles fit. as far as the speedo, the one of my S40 B000 fit perfectly along with the d16 differential bearings.
Old Jun 5, 2009 | 05:15 PM
Mista Bone's Avatar
D Tranny Guru
well then you have ZC LSD. good luck finding those axles and midshaft.
Cheap LSD just got REALLY expensive.
Old Jun 5, 2009 | 09:10 PM
usmcpab's Avatar
where there's a will there's a way. I did some research. All I need is the intermediate shaft and some DA axles. But im gonna custom fab my axles. that or selling it.
gimmethat
Oct 23, 2005 02:03 PM
ICeDoUt
May 24, 2005 12:03 PM
chackoperformance
Mar 21, 2004 11:16 PM
wtsexton
Mar 14, 2004 02:04 AM
20lb.teg
Oct 27, 2003 07:00 PM
