Stripped spark plug hole
Hi all... got a 94 accord lx, 2.2 (f22b2), 170k mi
I just got done doing a timing belt etc because the belt jumped and my timing was at 42*
I got everything back together and was doing a compression test to compare against pre-tear down. Anyhow I find out cyl # 4 has stripped threads
This is only the second time I've had the plugs out of my car as I've only owned it for 35k. I did not over-tighten, that cylinder has felt iffy and it was a pray and tighten scenario with it.
Has anyone successfully helicoiled a spark plug hole with the head still on? I know I've heard a different term used instead of helicoil for aluminum heads, but the name escapes me right now.
Any help would be greatly appreciated!
Aaron
This is only the second time I've had the plugs out of my car as I've only owned it for 35k. I did not over-tighten, that cylinder has felt iffy and it was a pray and tighten scenario with it. Has anyone successfully helicoiled a spark plug hole with the head still on? I know I've heard a different term used instead of helicoil for aluminum heads, but the name escapes me right now.
Aaron
jdmsiR20
11
Feb 9, 2006 04:53 PM
Dropped90Integra
Jan 21, 2006 09:24 AM
