Bosch 044/ Walboro Fuel pump/ Delphi/Lucas Injectors
Bosch 044 Pumps- 245$ Shipped
Bosch "044" fuel pump is our most popular high performance fuel pump. With reliability that the big German company is known for, it's our #1 choice in our workshop here. For upto 730HP at the flywheel or use two pumps for up to 1200HP on turbocharged applications.
As performance levels increase via greater airflow efficiency or higher boost levels, fuel delivery is crucial in developing maximum horsepower and in maintaining proper air/fuel ratios.
The Bosch In-line Fuel Pump upgrade replaces the factory pump to maximize flow for high boost applications where the factory injector pulse duration is substantially increased or where additional or larger injectors are utilized.
*Recommended for Turbo/Supercharged engines upto 600HP.
*Recommended for Naturally Aspirated engines upto 730HP.
*Flow Qty litres/hour (pressure): 200 (5 Bar) and 300lph@2 bar
*Inlet Connection: M18x1.5
*Outlet Connection: M12x1.5
*Length (mm): 196
*Diameter (mm): 60
*Max Power Consumption (Amps): 15.5
*Electrical Connection (-/+): M5/M6
*Methanol Tolerant
Our Bosch pumps are the genuine item and come sealed in their original Bosch yellow box.
Walbro 255LPH HP Fuel Pump Kit $95.00 SHIPPED
92-00 Honda Civic/Delsol GSS342/400-846
94-01 Acura Integra GSS342/400-846
Factory Honda & Acura fuel pumps are not designed to flow over 200 whp on a constant bases. Upgrading your fuel pump to ensure you are not running out of fuel pressure is a must on any performance application naturally aspirated, turbocharged, supercharged, nitrous etc.
Walbro High Volume In-Tank and Inline Fuel Pumps can handle up to 550-600 Whp! - One of the leading original equipment fuel pump suppliers, Walbro fuel pumps set the industry standard for quality and dependability. Walbro has entered into the performance world with the hottest selling and most frequently used performance pumps on the market.
Delphi- Factory Direct Injectors
High Impedance / Saturated
310cc - $219 per set of four injectors!
440cc - $219 per set of four injectors!
550cc - $260 per set of four injectors!
Low Impedance / Peak Hold
680cc - $255 per set of four injectors!
780cc - $255 per set of four injectors!
880cc - $255 per set of four injectors!
1000cc - $289 per set of four injectors!
California residence add for 9.75% sales tax
Payment Options:
Paypal, (Visa, Mastercard),
Money Order/Check/Cashiers Check.
Paypal id: Spoolindevelopment@gmail.com
Mailing Address:
SpoolinPerformance
43257 Osgood Rd
Fremont, CA 94539
paypal racerswholesale@gmail.com
in the notes include
forum name/user id
real name
tel number
item ordered.
forum name/user id
real name
tel number
item ordered.
