i think i gots a bad injector
Old May 29, 2009 | 12:15 PM
rick_rabies's Avatar
I'm not Rick!
Default i think i gots a bad injector
Ok I need a solution as what can it be that is wrong. Gsr motor, obd1 p28 with crome, turbo. precision 1000cc injectors, half tuned and was running
Problem: at first I didn’t have a resistor box hooked up. I an injector got stuck open flooding gas in. I guess the p28 was fried because of it I was told, so I bought another one with the same chip, wired resistor box and then it started right up alittle lean but it ran and not flooding
I drove about 10 miles and came home. i shut it off. And when I tried to start it again....that same injector flooded the cylinder again...
The resistor box is wired correctly, it had a new p28. Obviously the clips and wires were on correctly.. I was in boost driving for awhile then this happened..could it be the injector that is bad? Can they do that? Work and then not. Did I damage the injectors by not having the resistor box hooked up? do I just need new injectors? Is that 1st p28 still good?
Old May 29, 2009 | 01:00 PM
mtber's Avatar
Default Re: i think i gots a bad injector
I have never seen a precision injector go bad.
Your problem is probably related to wiring & your ecu being damaged.
Start replacing components one by one after re-checking your wiring.
Old May 31, 2009 | 11:50 AM
I'm not Rick!
prolly wiring, i tried 2 dif p28s? il check today
Old May 31, 2009 | 10:19 PM
rickfazz's Avatar
New User
Move the injector to another hole if it follows then it's the injector, if not then ur system is the problem
Old Jun 1, 2009 | 06:42 AM
I'm not Rick!
ok. thanx. cant now. the whole deal is out the car. strippd...agian
Old Jun 1, 2009 | 07:52 AM
I'm not Rick!
can a fuse be blown somewhere? is there a fuse for injectors?
88 EF Hatch
10
Aug 30, 2015 03:24 AM
schock3
Aug 25, 2009 12:37 PM
rick_rabies
Engine Management and Tuning
17
Jun 15, 2009 08:13 AM
rick_rabies
Jun 1, 2009 09:31 AM
krazeemidget
Nov 11, 2003 10:05 AM
