Odd tranny noise.
Old May 29, 2009 | 07:34 AM
diamondstarsforever's Avatar
Default Odd tranny noise.
Ok, So I've searched for a while but keep getting conflicting statements on this being either the input shaft bearing or the throwout bearing.
There is a "whiring" noise coming from the tranny of my girlfriend's 95 GSR. When I say whiring I mean it sounds like something resembling the noise a roller skate makes, but slightly higher in tone.
SYMPTOMS:
Constant noise.
It is not gear dependent.
It will make it while in neutral.
It will disappear totally with the slightest touch of the clutch pedal, but will return as soon an you let off.
Thoughts, Opinions?
Old May 29, 2009 | 07:54 AM
Ruben19's Avatar
Default Re: Odd tranny noise.
main shaft bearing
Old May 29, 2009 | 08:00 AM
mouab18c1's Avatar
main input shaft bearing. mine does the same
Old Jun 15, 2009 | 06:15 AM
Pulled the trans case apart, and replaced the ISB. It was for lack of a better word "perfect", The throwout bearing on the other hand was dry, noisy, and loose when I spun it by hand. Also, One of the TOB's retaining tabs was broken off ,so I assume it was letting fall against the clutch when it wasn't engaged giving it the symptom of constant noise.
Old Jun 15, 2009 | 09:50 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Dang, sorry I didn't see this earlier. I could have told you it would be the TOB, since the noise went away when touching the clutch pedal.
RG400SmartTowel
Transmission & Drivetrain
Oct 22, 2009 06:18 PM
jmm96gsr
27
Jun 25, 2009 06:30 PM
dRuNkEnMoNkEy97
Nov 9, 2007 07:59 AM
Jdm_Eg686
15
Oct 9, 2007 12:19 PM
boostinb20vtec
Apr 22, 2004 04:32 PM
