Honda S2000 Honda S2000
clunk/pop noise from rear when pulling out
Old May 28, 2009 | 08:10 PM
danthemang3's Avatar
Default clunk/pop noise from rear when pulling out
it's been going on for a month or two. but almost all the time when i pull out from a stop and sometimes even going from 1st to 2nd i get a clunk/pop noise from the rear of my s2000. it seems like it's coming more from the right rear but could be wrong. i checked all the mounts and changed the rear diff fluid and used a paint filter to strain the fluid and it was squeaky clean. any ideas guys?
Old May 28, 2009 | 08:20 PM
Casey's Avatar
Default Re: clunk/pop noise from rear when pulling out
maybe the exhaust. my car does it as well but seems to be left side
Old May 29, 2009 | 06:32 AM
JDogg's Avatar
I had a few s2000's come into the shop with a pop from the right rear, ended up being the lower rear ball joint.
its a pain, b/c you cant get that ball joint separate, it comes attached to the rear knuckle.
if you can get the car on a 4post lift, put a pry bar between the LCA and the knuckle, if the joint is bad you will be able to move it. if the weight is off the joint its harder to see.
Old May 29, 2009 | 07:30 AM
thanks man i'll give that a try
Old May 29, 2009 | 09:02 AM
race2win502's Avatar
ck the axle nuts, thats what mine was
Old May 29, 2009 | 02:15 PM
bky's Avatar
bky
axle nuts tend to knock every revolution when loose (trust me). I suspect a bad axle.
http://www.harborfreight.com/cpi/cta...emnumber=99849
This tool is the best for removing the ball joints. Pittman arm pullers won't fit, and forks are just bohemian. This one comes in from the side and works better than anything else I've used.
S2KRIDERAP2
Honda S2000
Jun 20, 2010 05:13 AM
desi01
Dec 18, 2009 04:40 AM
jamsicle
Honda S2000
17
Sep 1, 2006 08:58 AM
ZipTieGUy
Mar 8, 2006 10:24 PM
killaj12
Apr 4, 2005 01:23 PM
