car shakes alot when started after sitting overnight help!!!!
Old May 28, 2009 | 07:37 PM
luis1855's Avatar
Icon6 car shakes alot when started after sitting overnight help!!!!
i have a 95 integra ls 127*** about a month ago my timing belt snapped!! while driving it damaged some valves they got replaced along with water pump and a new belt here's the problem after my car been sitting overnight i start my car it shakes like crazy and if i try to drive it right away the rpm's drop and sometimes it stalls but after it warms up it drives normal the mechanic said the cat could be clogged i replaced that with a magnaflow cat still the same what could be the problem?? please help!!!!!
Old May 29, 2009 | 01:37 PM
luis1855's Avatar
Default Re: car shakes alot when started after sitting overnight help!!!!
Nobody??
Old May 29, 2009 | 01:59 PM
stevenDAtegra's Avatar
Does the car sound fine while it's shaking or a little different. I know low oil pressure will make it shake.
What oil viscosity are you using too?
Old May 29, 2009 | 02:10 PM
luis1855's Avatar
10w30 the car sounds fine before the whole timing belt snapping the car was fine compression is 180 on 3 and the other 170..idk if it matters but after I start the car the oil light stays on for like 3 seconds
Old May 29, 2009 | 02:17 PM
Hmm, I cant quit remember if the oil light always stays on for 3 seconds or not and can't start my car since it is untuned right now.
Do you have any oil leaks anywhere by any chance? What I would maybe try to do is flush the system with that oil you run your car on for a little bit then drain. Maybe your oil pick up is dirty or your oil pump may be going out.
It seems as if though you are losing pressure which would only be from a leak somewhere right?
Old May 29, 2009 | 03:50 PM
luis1855's Avatar
Ima try That but why when it's warm it's all good? And no leaks anyplace could the valves have anything to do with it?
Old May 30, 2009 | 07:14 AM
Once the oil warms up it flows better and is easier for it to be pumped.
Did this start occurring right after you got the valves replaced? Does the headgasket have oil anywhere around the edges and was it replaced?
Old May 30, 2009 | 07:53 AM
luis1855's Avatar
Yeah right after.. the head gasket is new and no oil around but the whole oil thing makes sense cuz after it warms up is good not 100% the car still seems a lil slugish so wat should I do??
ninjaturtleEG
Nov 11, 2011 07:45 AM
Kagelude
Sep 1, 2009 08:10 PM
bboixtc
Apr 6, 2006 01:55 PM
btramm
Sep 3, 2004 08:22 AM
rokestah
Feb 3, 2003 04:20 PM
