Transmission & Drivetrain Gearboxes, Differentials, Clutches
what halfshafts work for this.
Old May 28, 2009 | 06:26 PM
quinnyboy's Avatar
Default what halfshafts work for this.
I have a 90 civic hatch dx with a b18a1 donor motor from 91 teg obd0 but i was wondering if anyone knows (i have the shafts from both cars both manual non abs) what the difference in lengths are so i can get them machined or if anyone knows a good site for custom shafts and shift linkage for this aplication of swap?
Old May 28, 2009 | 06:27 PM
quinnyboy's Avatar
Default Re: what halfshafts work for this.
i also have both the knuckles and spindles from both vehicles.
Old May 28, 2009 | 07:11 PM
FIGARILA's Avatar
You shouldn't need any kind of custom shafts or perform any modifications, unless you are using some whack homemade mounts. When i did this same swap i used old school Place Racing mounts and i had to use (1) DA axle and one 1st gen integra axle. As for the shift linkage that has been covered many times here just look at the FAQ thread in the EF forum.
Old May 28, 2009 | 07:17 PM
quinnyboy's Avatar
thanks for the post i think someone had originally put a b16 or d16 in it measurments taken measured that of the teg. so i figured direct drop in but i just wasnt sure about the half shaft fit in the spindles or the tranny.
Old May 28, 2009 | 07:42 PM
quinnyboy's Avatar
so you remember which side cvs where from which side/years
Old May 28, 2009 | 07:45 PM
quinnyboy's Avatar
thanks for your help.!!!!
Old May 29, 2009 | 12:56 PM
FIGARILA's Avatar
lol...i actually don't remember. What issue are you running into now? is one spindle hard to put on the car.
Old May 29, 2009 | 08:05 PM
quinnyboy's Avatar
no i actually haven't tried to drop it yet just wondering before i do cause it would be much easier that way
Old May 29, 2009 | 08:08 PM
quinnyboy's Avatar
as for the shift linkage i cannot access this faq section of the ef forum because i havent been her for 15 day or whatever the rules are. but i did more research and found some stuff out just wish i knew how much i had to cut the teg linkage
tgraeter7
Jul 31, 2011 07:50 PM
WiLLMaTiX
Oct 18, 2004 05:56 PM
ChaseIntegra
Jul 18, 2003 03:43 PM
biggdogg
Feb 28, 2003 06:23 PM
