ignition box, ss clutch line, brakes and more obo must go!
Old May 28, 2009 | 04:58 PM
MrParks's Avatar
Default ignition box, ss clutch line, brakes and more obo must go!
golden eagle b16/ls manifold w/ accufab 90mm tb with v band clamp attachment.
this is a ge intake manifold with a 90mm accufab tb. 90mm tb flanged already welded comes with everything, gaskets, v band, tps sensor, ge billet blk anodized polished f rail bored for domestic injectors, comes with -8 an fittings for quick and simple install. ported runners. everything is setup and no need to fabricate anything to make this work. throttle cable is a simple 99 Si or ls throttle cable already made. 1000.00 + into this manifold.
820.00 shipped or make an offer no trades.
exospeed fully built long block
765+hp 30 psi. ls vtec long block comes with everything you need no fuss, and built by exospeeds reputable and reliable engine builder/ machinists. many can vouch for this setup/platform.
serious buyers only
starting bid at 3800.00 paid 5000.00 with no cover or dist, many extras. does not come with damper.
i will express details on the internals to serious buyers only. very stout motor. please pm me.
TURBO OIL FEED/EVAC KIT
-comes with everything you need for your turbo
$115.00 shipped.
Jacobs PRO Street Ignition box lil dusty but new and never installed.
i have used jacobs ignition systems on many other cars with no problems after 10 years of use. very reliable and great power.
blows the msd digital 6 out of the water and willing to part ways for dirt cheap. normally sells for over 480.00+ seen on summit and other sites
stats on the ignition box:
Brand: Jacobs Electronics
Product Line: Jacobs Digital Ignitions Pro-Street Kits
Part Type: Ignition Box and Coil Kits
Part Number: JAC-372546
Circuitry: Digital
Rev Limiter: Yes
Ignition Box Output: Capacitive discharge
CD Voltage Output to Coil: 535 V
Minimum Operating Voltage: 7.5 V
Maximum Operating Voltage: 18 V
Current Draw: 11 amps at 10,000 rpm
Spark Output (millijoules): 145 Millijoules
200.00
FCS clutch line kit. this kit is for clutch master to slave. eliminates all the oem lines to the slave. looks really nice. comes with 2 fittings and ss line with clear jacket.
65.00
FCS brake line kit new in the bag with clips,bolts,washers,etc. lines comes with mounts and a clear jacket to cover the ss braided line. fits civic/integra, ek, da, em very nice. sells for 139.00 just removed it to take pictures.
90.00
1/4" d.o.t. air brake push lock vaccum / boost kits
everything you need to plum your turbo or vaccum lines. stainless steel fittings with high temp high impact d.o.t approved fittings and firestone d.o.t air brake lines.
plum your twin wastegates, boost solenoid, b.o.v, fpr, boost ref, and vacuum all in one package
$90.00 SHIPPED
6ft of fire sleeve in black and in silver. fits hose sizes -3 to -6
40.00
please pm me or if you need immediate response since this sale thread is first come first serve, please email me or aim
hellomrparks@yahoo.com
aim: jparks8832
Old May 29, 2009 | 02:56 PM
MrParks's Avatar
Default Re: ignition box, ss clutch line, brakes and more obo must go!
bum ttt
Old May 30, 2009 | 01:11 PM
MrParks's Avatar
BUMP TTT
Old May 30, 2009 | 01:24 PM
UNKNOWN_MEMBER's Avatar
PMed
Old May 30, 2009 | 01:29 PM
EcHoB18C1's Avatar
PM'd
Old May 31, 2009 | 01:55 PM
MrParks's Avatar
bump ttt
Old May 31, 2009 | 02:08 PM
Japankid's Avatar
up for MrParks i will let u know about the parts iam going to tell my buddy
Old May 31, 2009 | 09:34 PM
MrParks's Avatar
thanks buddy i appreciate everything1!
Old May 31, 2009 | 09:38 PM
Dead CIVIC's Avatar
Veteran: Army
bump
Old Jun 1, 2009 | 11:18 AM
Japankid's Avatar
Old Jun 1, 2009 | 11:58 AM
MrParks's Avatar
ttt
Old Jun 1, 2009 | 02:16 PM
MrParks's Avatar
thanks for the bumps !!
Old Jun 1, 2009 | 04:23 PM
MrParks's Avatar
bump ttt
Old Jun 2, 2009 | 06:36 PM
MrParks's Avatar
bump ttt
Old Jun 2, 2009 | 06:49 PM
Japankid's Avatar
ttt
Old Jun 2, 2009 | 07:25 PM
Your Name's Avatar
XXX
Old Jun 3, 2009 | 12:41 AM
leeftwisted_db8's Avatar
pm'd
Old Jun 3, 2009 | 09:08 AM
Japankid's Avatar
ttt
Old Jun 3, 2009 | 02:24 PM
MrParks's Avatar
thanks for the bump!!
Old Jun 3, 2009 | 02:31 PM
Japankid's Avatar
np ttt
Old Jun 3, 2009 | 06:40 PM
MrParks's Avatar
bump tttt
Old Jun 3, 2009 | 06:44 PM
Japankid's Avatar
up
Old Jun 4, 2009 | 12:45 PM
MrParks's Avatar
bump ttt
Old Jun 5, 2009 | 01:09 AM
MrParks's Avatar
ttt
Old Jun 5, 2009 | 01:15 PM
MrParks's Avatar
bump ttt
