96 accord ex two questions
Old May 28, 2009 | 02:41 PM
bdmlilburn's Avatar
Default 96 accord ex two questions
is the vibrating control solenoid that controls the fluid in the rear engine mount necessary? will removing it cause any harm to the engine other then having some extra vibrations under 1k rpms?
also what would be a good program i could buy to self tune the f22b1
Old May 28, 2009 | 03:26 PM
accord99power's Avatar
Default Re: 96 accord ex two questions
i dunno much about the vacuum rear mount, but i would assume if honda designed it that way that without it would cause more vibration and other mounts to eventually wear faster.
what kinda of tuning are you doing, whats your setup?
Old May 28, 2009 | 03:56 PM
bdmlilburn's Avatar
its a na setup
im just looking for a basic tune. really the only bolt on i have atm is a sri and the car is sucking in soo much more air. ide like to make sure the air to fuel ratio is where it should be and also have control over the vtec
Revel8r
Jun 11, 2013 03:29 PM
imamachine
Mar 19, 2013 10:34 AM
VanceG
Dec 7, 2010 04:09 PM
bdmlilburn
May 28, 2009 09:42 PM
bdmlilburn
May 5, 2009 07:09 AM
