Transmission & Drivetrain Gearboxes, Differentials, Clutches
Finding the optimal final drive ratio
Old May 28, 2009 | 12:19 PM
vinuneuro's Avatar
Default Finding the optimal final drive ratio
Calculating optimal individual gear ratios for a given tq/power curve is relatively straightforward. But how do you match a final drive drive for an engine? Or does it not work that way, in that you don't match a final drive to an engine, but only to a particular track (circuit)?
Old May 28, 2009 | 03:58 PM
Honda Bull's Avatar
Default Re: Finding the optimal final drive ratio
You're correct. FD is not matched to the engine solely, but what you are doing with that engine and the necessary speed required. It gets calculated both with the gear ratios being used and what needs to be attained at the particular track.
Old May 28, 2009 | 09:28 PM
MFactory's Avatar
We like to think of the FD as a "fine tuning tool", used in conjunction with the overall gear ratios to increase/decrease the overall speed required for that particular circumstance.
Two tools for you to use:
1) Gear Calculator - http://www.teammfactory.com/gearcalculator.php
2) Torque Calculator - http://www.teammfactory.com/torquecalculator.php
Enjoy
Old May 29, 2009 | 12:54 PM
Aquafina's Avatar
By track.
Tired of chaning the FD in my close geared trans, I'll be building another two trannys later this year so I have three to choose from for any given track.
Old May 29, 2009 | 06:06 PM
577HondaPrelude's Avatar
Most of the road racing track that I race at we hit a top speed of about 130mph max, thus I use the FD that will top out at about 135ish. Anything that gives a higher top speed is just going to give up acceleration, and anything lower will run out of gears.
Some of the big race teams change FD's and even gears based on track. That's not something I'm willing to do.
671XxDaRkCyDexX
Aug 26, 2008 06:46 AM
Midori Green
Apr 30, 2008 09:11 PM
DARKTEG_
Aug 19, 2006 06:56 AM
dmingis
Jun 13, 2005 03:01 PM
bocian
Apr 16, 2002 08:58 PM
