Honda S2000 Honda S2000
hydrolocked s2k
Old May 28, 2009 | 10:29 AM
kingofbattle909's Avatar
Icon2 hydrolocked s2k
disregard
Old May 28, 2009 | 02:24 PM
brandonS2k's Avatar
Default Re: hydrolocked s2k
Im assuming the car had a CAI on it? Other wise he would've had to driven it into a lake to screw it up that bad. Give more info if you can because the last time I had a friend that hydrolocked, he had to get a new motor.
Old May 28, 2009 | 02:26 PM
TheRappist's Avatar
See if you can't get an airhose down in the cylinders and blow it out. Buy new plugs too.
Old May 28, 2009 | 02:27 PM
TheRappist's Avatar
Also, make sure there isn't a 'pool' of water inside the intake system, aka from filter all the way to the manifold runners.
Old May 28, 2009 | 06:10 PM
92HB_HB's Avatar
I"d first kick the roommate's **** and make him pay for the damages.. There are reasons why some people don't drive nice cars..
Old May 29, 2009 | 02:41 PM
ReddotsS2K's Avatar
You should have made sure no water was left in it...rig up a vacumm, tape a smaller hose to it and put it down inside the spark plug holes. I would also do a compression check to make sure nothing is seriously fudged. As far as getting no spark i have no idea!
Old May 29, 2009 | 02:46 PM
FogDarts's Avatar
compression test once you are sure all water is out of it.
Old May 29, 2009 | 03:00 PM
disregard
Old May 29, 2009 | 03:09 PM
slim689's Avatar
Was the roommate even aware that he couldn't drive it through a puddle? The majority of people do not modify cars, therefore they do not have knowledge of these kinds of things.
I honestly don't think he should be at fault if he / she was unaware of the circumstances. IMO it should be the responsibility of the owner to explain what happens if you drive it through water. Given the fact that most cars can take a mere puddle.
Old May 29, 2009 | 03:15 PM
brandonS2k's Avatar
I kinda figured theyd total it if he took it in some where. The only reason my afore mentioned friend got a new motor and not have his car totaled is because he was able to write it up as flood damage. Lol and his insurance company worked it that way
Old May 29, 2009 | 04:02 PM
REEMB18C1's Avatar
be sure to add oil in the cylinder to help build some compression what are ur compression nums
Old May 29, 2009 | 10:46 PM
yuedarklord's Avatar
Change the oil, do compression test, and get new spark plugs.
Old May 30, 2009 | 07:45 AM
dparm's Avatar
New User
Sounds like he drove through more than just a puddle. You need to hit some serious standing water to hydrolock.
Old May 30, 2009 | 04:38 PM
ReddotsS2K's Avatar
morons. your friend=failure
lfdelar2
Aug 22, 2013 06:12 PM
dc28012
Aug 1, 2005 05:03 PM
TXaccord
Nov 24, 2003 07:04 PM
wuhungsixxx
Jul 17, 2001 07:01 AM
