FS: OBD0 B16, Y1 trans, OBD0 ECU in So. NY
From: Where the wild things are in, NY, United States of America
OBD0 B16
Y1 Trans
ECU
All stuff is for local pick up near Newburgh NY. Taking offers, really have no use for this stuff so I need it gone.
***will have pics up tonight at 8:00 EST***
ALL ITEMS ARE OBO. PICK UP ONLY. PM ME OR IM ME ON AIM AT THE NAME ON MY PROFILE.
Thanks.
- Ran until I pulled it
- Leaks water, probably in need of a new water pump
- Needs Injectors
- Noisy LMAs (as most OBD0 B16's do)
- Needs a new cam seal
Y1 Trans
- Comes with Exedy stage 1 cable clutch
- No serious issues except the standard grind-into-2nd-at-high-rpm issue
- Will throw in clutch cable (good one with the metal adjuster)
ECU
- It works? Its a PW0.
- Also have engine bay harness that worked with it, the only thing it would need is a resistor box wired in.
Thanks.
morningstar
Mar 27, 2006 02:35 PM
