Boosted ek civc coupe Fs/Ft deland FL
Old May 28, 2009 | 04:02 AM
Wyzdum's Avatar
Default Boosted ek civc coupe Fs/Ft deland FL
-1998 Honda civic coupe
2000 si full interior (including darker gray panels and dash)
2000 si doors converted correctly
red suede door inserts,center,headliner
s2000 steering wheel
2 pod gauge cluster bezel (stock avail also)
15"gold dr28 w/ h centers and drags included wrapped with 205/55/15 khumo ecstas
Eibach springs on stock struts
2 1/2 in full piping w/flex straight to a greddy evo2 exhaust (sounds beautiful)
2000 si front end with black housing headlights
car has almost complete wire tuck
aluminum radiator
legit gsr block with arp headstuds
LS tranny w/ stage 4 xtd cluth (less than 300 miles on it)
fresh resurfaced flywheel
all bseries mounts
EXTRA PARTS
-full boost setup
ar.50 trim turbine garret internals NO SHAFT PLAY AT ALL!
turbonetics deltagate external wastegate
mini ramhorn manifold
downpipe
oil lines/fittings
bov
big FMIC
450cc obd2 dsm inj w/ res box
greddy turbo timer
boost gauge and air fuel gauge
oil catch can
all piping and clamps
all vaccum lines and t's
2 bar map sensor with plug
-also AGX 4way adjustable struts with skunk2 springs
-complete LS head
This is the situation i ran the car untuned on 15 lbs. and i cracked the cylinder wall and piston
the head is gone ..so basically all you need is a bseries longblock( or just a block since im throwing in the ls head) and you be good to go
im looking to trade for something else .... throw me some offers email pix too plz
asking 5k as is ...any questions please tex or call 4073102594
Old May 28, 2009 | 05:41 AM
MrGurley's Avatar
Default Re: Boosted ek civc coupe Fs/Ft deland FL
bump for yellow plate...
Old May 28, 2009 | 10:28 AM
Wyzdum's Avatar
lol thnx
Jim Truett
May 28, 2008 09:06 PM
ramrod
Aug 9, 2006 07:23 AM
budnick
Aug 4, 2004 06:56 AM
Hoodwinked
Apr 8, 2004 06:35 PM
Hoodwinked
Apr 3, 2004 09:29 AM
