Energy Suspension (ES) Shifter Bushing info
Old Aug 19, 2002 | 12:46 PM
Chris N's Avatar
Default Energy Suspension (ES) Shifter Bushing info
I searched... still have a few questions.
1. Level of difficulty for install. (I would assume it is not too hard)
2. Couldn't seem to find these items for sale. Where are they available? $$?
3. Did you find that it did the job well?
Thanks in advance.
Old Aug 19, 2002 | 12:52 PM
TypeR 599's Avatar
Default Re: Energy Suspension (ES) Shifter Bushing info (1107)
oh man B2 and i installed them together...
1. It's a bitch...seriously you need more than 2 thumbs to get them in
2. not sure where to get them but they were about 12 bucks.
3. it made shifting feel more crisp. not as loose
Old Aug 19, 2002 | 12:55 PM
Chris N's Avatar
Default Re: Energy Suspension (TypeR 599)
Go go Gadget extra thumbs!! Thanks for the info. Anyone know where to get them?
Old Aug 19, 2002 | 01:09 PM
Back in Black's Avatar
Rather OG
Default Re: Energy Suspension (1107)
http://www.summitracing.com
Old Aug 19, 2002 | 01:11 PM
SamC's Avatar
Default Re: Energy Suspension (Jason Franza)
I got mine from summitracing as well..
get some grease...it'll make the installation easier
Old Aug 19, 2002 | 01:16 PM
slowassR's Avatar
Put some in my friends civic....NO FUN. Personally I did not like the way it effected the ride quality. http://www.energysuspension.com/
[Modified by slowassR, 5:23 PM 8/19/2002]
Old Aug 19, 2002 | 01:31 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Energy Suspension (slowassR)
Shifter bushings, not suspension bushings. And of course it's going to make it ride stiffer!
The install isn't too bad. I crushed the flared pipe to fit the bushing on, and then reflared it. Sounds a lot more fancy than it really was. All I used was a vice grip
Warren
Old Aug 19, 2002 | 01:59 PM
Jason's Avatar
Default Re: Energy Suspension (Warren)
they were not hard at all....it makes it much easier if you take the shift linkage off to get the one bushing in there...
I tried doing it while on the car for about 20 minutes, no luck........took it off and it took literally 5 seconds....
Old Aug 19, 2002 | 02:12 PM
h8r's Avatar
h8r
Default Re: Energy Suspension (Jason)
http://www.suspension.com/acura.htm
Looks like $8 for the set:
1990-00 Transmission shifter stabilizer bushing set 16-1101 $8.00
Old Aug 19, 2002 | 02:16 PM
norice's Avatar
Default Re: Energy Suspension (h8r)
I am not sure I would recommend this modification. I recently installed Mugen's hard rubber shift linkage bushings and, while they do firm up the feel of the shifter, I think they make it a little notchier. I would suspect polyurethane bushings would be worse. The stock feel is really rather good.
Old Aug 19, 2002 | 02:19 PM
Jason's Avatar
Default Re: Energy Suspension (norice)
stock feel is too sloppy...the poly bushing aren't too stiff IMO...just right
beware ordering from Summit....like 10 bucks, but they nail you w/ a $7 handling fee per order, so it sucks if that's all you want to order
Old Aug 19, 2002 | 02:24 PM
Tommy_Gunns's Avatar
Exactly what I did. Take the extension arm off and it is easy as pie.
Old Aug 19, 2002 | 02:25 PM
AllMotorITR's Avatar
New User
Hey Norice, Since you live close to me, you think I could check out the feel of the shifter now that you have the Mugen bushings in? IM me.
THE94GSR
Feb 2, 2004 06:50 AM
johnzm
Sep 16, 2002 05:02 PM
