Fs: b16 head, b20 block, godspeed, ls trans, hasport, function form, supertech!!!
1990 b16 complete head minus the intake manifold. It has been machined to use ls dowels with a ls headgasket. Its been plugged and has the 10 an- fitting on the back of the head. It also come's with a golden eagle sandwich plate with the oil line. $400 obo picked up or $350 for the head by it self
B20b shortblock- cylinder walls have a lil surface rust but u can wipe it off with your finger. Nothing a bore and hone wont fix . Still has stock pistons it it. $200 picked up
I got some brand new sparks racing 84.5mm cast pistons also ..comes with rings (same as the rs pistons) $280 picked up or if u wanna buy the block together $400 for the block and pistons.
Brand new Hasport efb2 mounts (These mounts make B-series engine swaps into the 88-91 Civic or CRX a simple, bolt-in process. The kit is designed to work with the B-series engine and the hydraulic transmission.)$390obo
LOCATED IN VENTURA COUNTY (CAMARILLO)
