Will 09 Civic SI Exhaust Direct Bolt on 99 Civic?
Old May 27, 2009 | 09:02 PM
HondaKid99's Avatar
Default Will 09 Civic SI Exhaust Direct Bolt on 99 Civic?
Hey guys. I tried my hand at searching, but came up with no results.
Will the stock exhaust from an 09 Civic SI (2dr coupe) direct bolt onto a 99 Civic (2dr coupe)? I'm talking from the cat back.
If its not a direct bolt on, has anyone made it work and how much modification is required?
Appreciate the assistance.
Old May 27, 2009 | 09:12 PM
mynameizstitch's Avatar
Default Re: Will 09 Civic SI Exhaust Direct Bolt on 99 Civic?
im positive it will not directly bolt on. just take it to a muffler shop they can cut and weld it on to fit.
Old May 27, 2009 | 09:15 PM
Deetz's Avatar
Crazy Honda Guy
hmmm, well, it's not the same car....so NO
why would you assume it is direct?
Old May 27, 2009 | 09:20 PM
90_EX_Civic's Avatar
dont know 100% but the axle back should fit. the cat back won't, since the pipe goes under the passenger seat.
Old May 27, 2009 | 09:23 PM
HondaKid99's Avatar
Thanks.
That's why I asked man. The guy I'm looking to buy it from claims it's a direct bolt on. I figured someone on here had gone down this route before. Thanks for your response tho.
Old May 27, 2009 | 09:24 PM
HondaKid99's Avatar
Ahh..I did not know how the 09 exhaust was configured. That pretty much puts a definate no on the cat back. Thanks!
Old May 27, 2009 | 09:26 PM
Deetz's Avatar
Crazy Honda Guy
^^ different chassis completely! The engine is mounted backwards from the older style D and B series engines.....i seriously doubt any of it would bolt on.
That being said, anything can be modified to fit, if your willing to spend the coin at a muffler shop
CivicHP
10
Apr 30, 2006 11:23 AM
spidermancivic
Welding / Fabrication
Jan 24, 2005 03:32 PM
speedymon
Jul 17, 2002 08:08 AM
