I finally made it to the dyno! Pics and Video inside!
Old May 27, 2009 | 07:58 PM
soulassassin13's Avatar
Default I finally made it to the dyno! Pics and Video inside!
I have finally made it to a shop for a Hondata S300 install and a tune. My modifications are a Mugen intake, Hytech big tube header, and Hytech twin loop exhaust on a internally stock JDM B18C*R engine.
Now for the pics!
Installing the Spoon Cam Gears
Hooking up to the Dynopack
The Mugen Intake and the Hytech Header
Hytech goodness!
Minty new valve cover
The 4th gear dyno pull on the S300
Feels P73 ECU vs. Hondata S300 final tune & spark plug change
Final pull on 4th gear
Old May 27, 2009 | 08:10 PM
redGSRguy's Avatar
Default Re: I finally made it to the dyno! Pics and Video inside!
So what was max power/torque? Hard for me to see on those images.
I have a similar setup mugen intake/hytech prototype header and smsp exhaust.
185/124 only on a dynojet.
Old May 27, 2009 | 08:24 PM
In a 3rd gear pull it topped out at 211hp, but the power curved spiked in some strange spots i.e. after VTEC engagement and around 7800rpm. The tuner could not smooth out the power band on a third gear pull and believe me he tried almost everything (pulling engine timing for like 2 hours. He attempted the tune again in 4th gear and we got a more natural power and torque curve. On the 4th gear run we peaked at 194whp and 133lb/ft of torque. Both numbers I am very happy with.
We were trying to figure out why we had the power spikes in third and more peak horsepower. He hypothesized that it was maybe the angle the gears were cut ultimately equaled less transmission loss to the ground.
Old May 27, 2009 | 08:47 PM
red_crx's Avatar
Good power for basically nothing but bolt ons. Whats with all the smoke in the video..was it cold outside?
Old May 27, 2009 | 08:57 PM
alexpr's Avatar
nice!!!
Old May 27, 2009 | 09:05 PM
It wasn't cold out. It was about 72 degrees all day.
Old May 27, 2009 | 09:28 PM
BoS_DC2's Avatar
Originally Posted by gjdgfd
what a lame way to advertise...
On topic:
sweet numbers man!!
Old May 27, 2009 | 09:29 PM
Somebody ban this guy!
Old May 27, 2009 | 09:37 PM
99SlammedCivic's Avatar
Snipper Snapper
Looks like your motor is about to blow up based on the amount of smoke.
But hey, it could be valve seals or piston rings
Old May 27, 2009 | 10:07 PM
WheaMyRyceGo's Avatar
you're blowing tunes of smoke but the car is putting down good numbers...
Old May 27, 2009 | 10:10 PM
Ausmith's Avatar
VTEC engagement looks a little high.
Old May 28, 2009 | 06:34 PM
Snipper Snapper
Better start adding oil every 500 miles !
Old May 28, 2009 | 07:51 PM
wegotmorrison's Avatar
Dayyyyyyummmmm Homeboy SMOKES
Old May 28, 2009 | 09:12 PM
My motor does eat oil. Might be time for a rebuild this winter.
shahriar35
Sep 21, 2010 12:44 PM
smR_lsvtec
Jun 28, 2007 10:53 AM
smR_lsvtec
Honda S2000
30
Jun 27, 2007 09:19 AM
Type-R Yo!
Feb 7, 2004 04:34 PM
BABY NSX
Jun 6, 2003 11:12 AM
