Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Slight "clunking" noise from front passenger side of car!
Old May 27, 2009 | 05:57 PM
RICO_'s Avatar
NO MERCY!
Default Slight "clunking" noise from front passenger side of car!
It only happens when I'm traveling slow (5-10mph) and brake hard. It "clunks" the instant after I press the brake and the instant that the car comes to a complete stop i can hear a second faint clunk sound.
It doesn't make the noise when I'm driving, accelerating, or going over bumps, or when I brake normally. So now I'm at a loss and don't have a clue what it could be.
Now of course I'm no fool and I wouldn't be posting this thread if I hadn't checked the most obvious part first....my Skunk2 suspension.
I did....everything checked out fine. All the bolts were on tight. The Spring preload was snug, the sway bar was tight as far as I could tell.
All I have left to guess at is possibly something with the brakes, or a bad motor mount.
Any thoughts?
Old May 27, 2009 | 06:05 PM
blueDA9's Avatar
Default Re: Slight "clunking" noise from front passenger side of car!
anything in the trunk?
Old May 27, 2009 | 06:58 PM
vladd's Avatar
sticky brake pads?
Old May 27, 2009 | 09:06 PM
av911's Avatar
What car do you have?
Old May 27, 2009 | 09:08 PM
ironworker's Avatar
i think he has a nbp si
Old May 28, 2009 | 02:59 AM
RICO_'s Avatar
NO MERCY!
Topic title. Topic title. Read the topic title.
Old May 28, 2009 | 03:01 AM
RICO_'s Avatar
NO MERCY!
And yes I have an '06 Si 45K miles. Brake pads still have a good amount of pad left.
Old May 28, 2009 | 07:02 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
I had a problem with my front subframe being out of alignment, and had very similiar symptoms. Took it to the dealer and they loosened it all up, aligned it, and re-torqued everything and haven't had a problem since. A good test to see if this is the problem is while you are standing still with the motor on, turn the wheel from right to left very quickly with abrupt changes in direction. If you hear knocking sounds, that's your issue.
HTH
-Todd
Old May 28, 2009 | 02:16 PM
2008fijibluesi's Avatar
I have the same problem RICO. If you do find out what it is...please let me know.
Old May 28, 2009 | 02:59 PM
ironworker's Avatar
Does it sound like the heat sheild is trying to fall off? When i brake hard next to a high curb or wall i can hear a somthing a "clunck" or like somthing is hitting the heat sheild or sumthin?
Old May 28, 2009 | 03:55 PM
RICO_'s Avatar
NO MERCY!
Doubt it. I took it to the dealer and (as expected) they pinned the noise on the Skunk2 coilovers.....although they couldn't explain in detail what was causing the noise....they just said it was the front struts.
Technically they COULD be right.....but they could also have the mentality that they don't want to dick around with modified cars.
Old May 28, 2009 | 03:58 PM
i-VTEC_DOHC's Avatar
my friends car make a clunking noise also, but it turned out to be a blown sway bar bushing.
Old May 28, 2009 | 04:46 PM
My car made the noise before I installed my Skunk2 springs and it still makes the noise.
midnightsun
Suspension & Brakes
Feb 18, 2019 09:23 PM
black94lude
Jan 13, 2010 06:18 PM
GeekinEK
Nov 2, 2006 09:40 AM
lv6l
Jan 4, 2005 11:42 AM
gshockbreaker
Feb 12, 2002 12:59 PM
