car shuts off randomly
Old May 27, 2009 | 04:39 PM
r1lsr's Avatar
Default car shuts off randomly
My 02 Rsx has been randomly shutting off lately. I just got a new ignition switch and the problem went away for a few weeks then it started to happen again. It seems to be more frequent when I use my turning signals. The wipers, dash lights, turn signals, pwr windows, and ignition all shut off, but the stereo and headlights still work. Do you guys think it could be a bad fusebox or alternator? It even dies when the car isn't started in the on position.
Old May 28, 2009 | 05:14 AM
turboteg2nv's Avatar
Default Re: car shuts off randomly
Check your grounds.
Old May 28, 2009 | 05:32 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Originally Posted by turboteg2nv
Check your grounds.
100% agree.
All of those parts you listed are related and ran threw the same loom going threw the steering column. I would check the wiring for sure. Who put in the ignition switch?
Old May 29, 2009 | 12:10 AM
r1lsr's Avatar
honda put in the switch, I took it in to them and told them exactly what happened and told exactly what they needed to do to make die. But they couldn't get it to die. So, they just waited for the computer to throw up codes. They said they didn't know what it was, so I just said replace the switch. It worked for about two weeks, then it just started to do it again. I'll be sure to check the grounds. But, I just don't get how the turning signal circuit could blow out the on switch. The A/C still works, so I am really thinkin about getting all new wires.
Old May 31, 2009 | 07:48 PM
r1lsr's Avatar
it turnso out that, someone I don't know who right after I got my clutch put in, rewired the stereo ground to something and it came loose. Regounded it and the problem is now gone.
Old Jun 1, 2009 | 05:41 AM
Check your grounds.
Wow i'm good, e-beer for myself.
Old Jun 1, 2009 | 06:46 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I'll hel drink to that woohoo
Old Jun 1, 2009 | 08:59 AM
mannydc5's Avatar
mine is starting to shut off also. but it happens when i have the a/c on or when i make a U turn and the wheel is turned all the way. does someone have an idea on what it might be?
Old Jun 1, 2009 | 12:24 PM
DaveSi677's Avatar
good too see everything worked out for you buddy.
Old Jun 1, 2009 | 11:37 PM
r1lsr's Avatar
thanks, you can always depend on people on the forums for help..
treal512
Feb 20, 2015 06:50 PM
civic_driver
12
May 31, 2009 08:27 PM
badfish2282
May 15, 2009 08:45 PM
b00sted4dr
Jul 31, 2006 05:00 PM
